Originally Posted by jwells393
Depends on how you do it. If you remove the height screws and pivot the saddle 180 degrees about the intonation screw ........ then reinstall the height screws, the angle will be reversed.
That's what I do.
Although, I'm not sure why there isn't more love for the Danny Gatton method -- bend the screws, and there's a wide range of subtle adjustments you can make. With each half-turn of the screw, a side of the barrel takes its turn being "in front."
- Scott
