Old May 9th, 2008, 03:04 PM   #23 (permalink)
Brent Hutto
OK, just about correct between the G and D strings. The distance from nut to 12th fret is 327mm. From 12th fret to middle of the saddle is between 327mm and 328mm, probably closer to 328 (hard to read my plastic office ruler to less than a millimeter). But it's almost dead square, that distance being about 327mm on the treble E string and closer to the 328mm on the sixth string, that's either my measuring error or slot slop away from being square.
I'll take a closer look at intonation when I get home tonight. From your description it sounds like I should expect to see it go flat as I move up the fingerboard on the treble strings and go the other way on the bass, right?
ON HIATUS
Brent Hutto is offline   Reply With Quote
