Old May 7th, 2008, 02:55 AM   #81 (permalink)
ol man
ol man's Avatar
This amp is great!
I just have to:
- change the speaker
- go ceramic
- go alnico
- rechange to the original speaker
- get a closedback/openback/semiopen/flexi-/ported cab
- replace all the tubes with NOS (or JJ/Tesla)
- pull out the pcb's and hard-wire everything
- get this hard-worked clothwire everywhere
(yes, it does improve tone ...)
- change the transformers. more iron
- install effect-loop / remove existing loop
- use an attenuator
- go from 6L6 to 6V6 or K66
- bias hot for shorter tube-life
- install / remove master-volume
- add a gain-stage no, three gainstages
- bypass/add the negative feedback loop
- shorten the signal-chain
- bypass the eq
- add a black faceplate to my SF Fender
- change the red light to blue
- get an authentic-looking pre-nicotined grillcloth
- add a Weber cooper-cap
- change all the caps and resistors
- get tonebones
There. Now it sounds great!
ol man is offline   Reply With Quote
