Thread: Super Champ XD
Old May 5th, 2008, 01:42 PM   #11 (permalink)
Billm
An integrated circuit in there continually polls the control knobs to see where they're set. It sounds like that part wacked out. I'd chalk it up to "infant mortality." Generally if a semiconductor part makes it through burn-in, it'll last a long time.
Or it could be something as simple as a bad solder joint. Noise on the line that's sampling the front controls would give you very random behavior in the Super Champ.
Fender's warranty service on these amps is straightforward: They swap them out. No field service. The authorized service center only ascertains that the amp is broken and that it doesn't just need a fuse or a tube.
Billm is offline   Reply With Quote
