I looked at the fuschiacaster in the late afternoon sun and found about 15 blue flakes in the last clear coats.
I used a dental pick and removed them as I'd already sanded the surface with 600 grit on a rubber sanding block and didn't get down to them.
I'll get the holes filled in eventually.
I sprayed a couple of coats on the Skybluecasted to hold the glitter in place and took some close up to show what a daunting task it is to cover this rough surface. This is not an easy task but the end result is like looking into heaven.
