Originally Posted by ce24
I think I found the 470 spot on the schematic...going from left to rt it is attached along side the first 25uf-25vdc cap but the schematic calls for a 1 watt 470 will this 5w 470 screw things up?
Thanks
CE24
OK, these are TWO different values.
The smaller wattage 470
K can just go on the actual V2 tube socket (the 12AX7 socket).
The larger 470
ohm is your 6V6's cathode resistor as you mentioned and is in parallel with the 25uF bypass cap.
1w - 10w is fine for the 6V6's cathode resistor, but it shouldn't be any lower. The old schem shows this as a 1 watt, but guys today generally use 5 watt. It won't hurt it, but going with a lower watt than 1w may be very bad :)
The 470
K is a normal 1/4 to 1/2 watt, just like the rest on the board.
Again, be sure to differentiate between K and regular ohms.
