Originally Posted by btlnckr
So are you saying that chorus modulation is happening when the mix is turned up. And you only want delay? That's one reason I sold my Memory man. If I turned up the mix, I got chorus also, it drove me crazy. Can you turn off the modulation & still use the mix knob?
Thanks fo any replies as I'm thinking seriosly about getting one.
Brian
I believe he's saying, he wishes he could turn it up and get nothing but the delay signal.
You can run the delay with out a hint of 'chorus'... In fact, even with the modulation engaged, it's still not a chorus sound. It's more a simpler modulation to sound like tape echo. A very mild warble, maybe? It's not a strong effect at all. Even with it, the pedal doesn't seem to color your sound at all.
