Originally Posted by maestrovert
i highly doubt the noise you experienced is due to the EMG T P-ups...
Comps tend to accentuate any noise(s) in the signal chain, it's a pretty well known phenomenon.....however, same as you, i have found comps to add their own noise, which is why i don't use 'em ('cept at times -rarely- i will add very subtle "studio" compression when recording)....
Yes I belive that teh pickups are super clean. I'm an electronic engineer by trade so my 'wheels are turning' as to what causes the noise...compared to passive pickups plugged into the comp. One thought I have is that the Comps gain is naturally increased for small signals.... and if the EMGs are putting out SUCH as small signal when nothing is played...ie NO NOISE at all ....then the comp will max out it's internal gain and hence you hear it hiss... Theres a couple of experiemnts I can run...
