Old May 1st, 2008, 12:29 AM   #13 (permalink)
martyb1
martyb1's Avatar
I decided to go play with my f-holes tonight
I did the nightly spraying of the OSB girls and went to work on the other one
This top is almost 3/8" thick.I think it looks to thick through the f-holes
so I took the router and thinned it up around the holes
I think it just looks better,and when the binding is on it wont look so thick
I softened the routed part on the back with the sander and knocked off the fuzz on the inside of the f-holes
I think we are ready
Oh my this is fun.This binding I got from StewMac.It seems to be more brittle than the other stuff I have been using.You have to be real careful when you make the tight bend in the f-hole or it will kink.I went and stole mama's hair dryer to warm it up a bit.I decided just to do the tight part of the hole tonight and let it cure overnight.I tried to carry on but was scared I was going to pull the binding away from the wood if I tried to do it all at once.
I wasn't real sure if I should dye it first or bind it first.I think I will have better luck binding and trimming a bit first.Then I can clean up the glue seepage and then dye it.I am scared if I dye it first,I might end up sanding or scraping through the dye cleaning up the glue.Not sure but too late now
Before throwing it out,make sure it's not 16x13x1.75
martyb1 is online now   Reply With Quote
