Old April 27th, 2008, 07:02 PM   #142 (permalink)
Spunky99
Spunky99's Avatar
The binding is done as far as the glue stage. I used my Exacto saw to dispense with the extra material on the ends.
I started the slow process of scraping down the binding to match the body. This binding was too thick for my tastes so I routed shallow and will scrape it down.
There was some interest in my leaving the binding proud on the last build. The problem I ran into is that I have a shallow pool that needs to be filled with lacquer. I guess it's OK on the FuschiaCaster as I left mini mountains of flake all over. On this build, I will try to make the flake height more uniform. It will require a lot more coats of lacquer than a guitar sprayed with the flake but that is the desired outcome. By allowing the flakes to stand on edge and every possible angle, you get a finish that literally looks alive when it is moving. In the sun or under stage lights, this is the result and the extra effort is well worth it. IMHO
Spunky99 is offline   Reply With Quote
