Old April 26th, 2008, 12:11 PM   #61 (permalink)
milocj
Fuse holders fit the physical size of the fuse and for the values you'll be using they aren't specific to the amperage of the fuse. A 1 amp Slo-blo will be the same size as a normal 1 amp fuse...they are just built to take a momentary spike (like when turning an amp on) without blowing. They usually have a center inside the glass tube that looks like ceramic with a real fine wire wound around it whereas the normal fuses have just the wire going through them.
I would guess that for your amp you'll just get an in-line type fuse holder and you can wire it to the switch and one lead of your new power cord. You can probably get that and the fuse at Radio Shack, Home Depot, Lowe's, etc or I'm sure whoever you order parts from can hook you up with both.
milocj is online now   Reply With Quote
