Old April 24th, 2008, 07:55 PM   #11 (permalink)
RotelliCaster
RotelliCaster's Avatar
Originally Posted by jwells393 View Post
I think when you mount your pickup into the Bigsby bridge plate and place the pickup in the cavity that will pretty much locate the bridge for you. I'm sure you'll have a little movement Longitudinal and lateral directions. Measuring 25.5 inches from the nut can help locate it in the neck direction. To locate in the other direction you could use strings and weights like I did here.
It would be a little more difficult for you since the bridge would be loose. Once the bridge plate and bridge are installed, installation of the tremolo unit should be pretty straight forward.
Now that's what I was looking for!!!!
You were holdin out!
Thanks J
" Trust me, I saw this in a cartoon and I'm pretty sure I can do it! "
http://www.myspace.com/bmwsteve
Guitar Photos
RotelliCaster is offline   Reply With Quote
