Old April 22nd, 2008, 07:40 PM   #50 (permalink)
milocj
I didn't realize that I had the wrong schematic, but the values are likely the same. The picture you posted above shows that the 2uF cap is rated at 50V. I can't make out the other one which I assume is the 10uF.
I went back and looked at the original pictures and I can see 25V written on the cap that is C6 and I'm guessing it is the 25uF (that part is hidden in the picture). I'd probably go to a 50V on that cap but it should also survive fine with a 25V since it has so far.
Whenever you get around to doing the caps remember that these electrolytics are polarized and have to go back in with the positive end in the correct direction.
