Old April 21st, 2008, 12:05 AM   #7 (permalink)
jefrs
The VC15 has only one ext spk socket which shuts off its speaker. The VC30 has two so you can add another in parallel to the internal, it will have a switch to the o/p transformer for the impedance. If VC15 will accept a 16ohm load then it might accept two 8ohm speakers in series. Might and if. Its manual does indeed say 8-16ohm.
The 5W L5T-112 has two ext sockets and the low volume crunch. So you can run into a 2x12 (mine's into a GS212IE) setting as a 4ohm total load (16 parallel to 8). Now the 2x12 can be configured as a 4ohm so 8+4=12, so maybe...
The new Laneys have the magic tone control knob.
