Old April 12th, 2008, 11:47 AM   #3 (permalink)
mikespe
mikespe's Avatar
Originally Posted by eugenedunn View Post
First determine what impedance each speaker is. I looked at the user manual at the link you provided. Looks like your amp is a stereo setup with 2 discrete 30 watt amps?
And each speaker is a 4-ohm speaker. If that is truly the case, to make your cabinet the most useful, I would say you'd want to wire your speakers in series, and get a total impedance from the set of: 8-ohms. That should match up with the majority of amp heads out there.
Anyone else have an opinion?
Is there anyway I can set it up for both a 4ohm and 8ohm? I have a VibroChamp XD that is only 4ohm and I would love to have the option of using a cab with it sometimes. Also, It's been a LONG time since I wired speakers...do you have (or know of a) wiring diagram that shows how to connect the 2 speakers to the jack(s) (Jacks in case I can set it up for bot 4 and 8 ohm).
Thanks for your help.
mikespe is offline   Reply With Quote
