Originally Posted by Wally
So, Telzilla, could you share what you found with your computer cord....brown to hot? blue to common?
Yeah, that was it. But I'd check if you're doing the same thing someday.
I do think the setup of the plug itself is standard (at least in the US)- starting from the ground going clockwise, if the blades and plug are pointing at you, is Ground, Hot, Earth. Of course, that doesn't help if you can't see what color wire connects to what.
