Old April 11th, 2008, 09:14 AM   #3 (permalink)
TelZilla
TelZilla's Avatar
Originally Posted by z8894 View Post
"The scemo shows the brown AC Mains wire going to the 2A fuse, then to the switch. The layout shows the brown AC mains wire going to the switch, then on to the fuse. Does it matter where in this order the fuse is? "
No
"On the Schemo, shouldn't the wire labeled black which runs from the PT (T1) to the switch (S1) be either blue for 125V or Brown for 120V?"
Yes, the schematic doesn't show the same transfomer as the layout.
"One other thing- is the color coding of a three pronged plug standard? I'm reusing a cord from an old PC. I know the green wire is the round plug (the ground), but I'm not sure which of the two "blade" plugs the Blue and Brown wires connect to. I followed the color convention on the layout, and soldered the brown mains wire to the switch and connected the blue one to the black PT wire with a wire nut. Is it possible that the orientation of my power cord is reversed from the stock Weber one? Would it matter if it was? "
There is a standard but you've got a DMM, check for yourself. Learn to use the meter, it's very important to be good with it.
Are you a librarian? Cuz you are awsome at scolding.
Thanks,Nick
Go, cat, go!
TelZilla is offline   Reply With Quote
