Thanks guys.
You're absolutely right 4strings...It's twice as loud now when it's turned off, and my car and truck both go faster too:D Actually it sounds great with or without the right colour cloth.
Regretably I didn't rig up any internal beam-blocking apparatus, since it came to mind post-op which is a drag, but if I ever decide it really needs to be done, I'll spend another $35 and recloth again.
The aged silverface cloth looks real good, but when I did the recloth, I found remnants of the original cloth around a couple inner corner edges under where the drip edge goes; which turns out to be black/white/turqoise and not the aged black/white/light blue that I got from ampwares. All I ever got to look at was the black it had. Who knew?? :)
Anyway, You'd have to look real close, and the only telltale sign is the slight difference in light blue on the cloth to a more turqoise super reverb amp colour on the faceplate. Very minor.
Ignorance is bliss; and I just HAD to look at the website now didn't I?? AAArrrggg haha.
Ok....maybe the truck still goes the same speed, but I'm stickin' with the car and the amp.
Cheers
The looser the waistband, the deeper the quicksand; or so I have read.
