Old April 10th, 2008, 11:42 AM   #1 (permalink)
TelZilla
TelZilla's Avatar
5F1- AC Main, fuse, and switch wiring
Hey there. Still troubleshooting my current 5F1 build (from my desk at work...)
In comparing the Weber 5F1 Schematic
to the Weber 5F1 layout
I have some questions about the "order" of the wiring for the fuse and the switch.
  • The scemo shows the brown AC Mains wire going to the 2A fuse, then to the switch. The layout shows the brown AC mains wire going to the switch, then on to the fuse. Does it matter where in this order the fuse is?
  • On the Schemo, shouldn't the wire labeled black which runs from the PT (T1) to the switch (S1) be either blue for 125V or Brown for 120V?
One other thing- is the color coding of a three pronged plug standard? I'm reusing a cord from an old PC. I know the green wire is the round plug (the ground), but I'm not sure which of the two "blade" plugs the Blue and Brown wires connect to. I followed the color convention on the layout, and soldered the brown mains wire to the switch and connected the blue one to the black PT wire with a wire nut. Is it possible that the orientation of my power cord is reversed from the stock Weber one? Would it matter if it was?
Thanks.
Thanks,Nick
Nec Aspera Terrent
TelZilla is offline   Reply With Quote
