Originally Posted by TNO
I think cutting back on the negative feedback by about half would be just perfect...anyone know what value resistor that would be?
If you want half the amount of NFB, you'll have to experiment with higher value resistors. If you have a 47k in it now, which is is the mod that I prescribed, that is the same value the vintage GA5 had, try a 100K and see what you think. Then work your way up or down in resistor value from there. The higher the resistor value, the less NFB.
