Old March 19th, 2008, 02:08 AM   #22 (permalink)
boris bubbanov
boris bubbanov's Avatar
Originally Posted by MartineckArt View Post
Nocasters
I think the CS boys cut a little smaller bridge pup rout. My CS NOS No-Caster does not have any evidence of this, nor have others I have examined; every single AV52 FSR 60th Anniversary 'Inlay' I've seen has at least some of this issue, as J-man has said.
Over on the Ensenada side, it is the same issue. An additional reason, maybe a trivial reason for some, that I like the Callaham vintage bridge is that the Callaham is an eighth inch wider, and covers the dreaded 'butt-crack' in all but the most badly aligned Tele bodies.
BTW, USACG bodies, despite being scrupulously accurate about the router hump and the area around the jack rout, do not provide you with any butt crack. Moreover, the ferrule holes aren't misaligned like they're supposed to be.
Bubban0v
