Old March 15th, 2008, 05:59 PM   #52 (permalink)
Spunky99
Spunky99's Avatar
Most resins are thixotropic, which means if you push them hard when they are liquid they act like water, but when you leave them alone, they act like cold honey.
Been there, done that. Exotherming polyester resin makes it thick as water but it hardens in a snap and then gets hotter than heck and has a slight amber tint.
The end result is faster but will be about 1/8" thick. I think the total thickness for the method I'm using will be about 1/16" total.
I got busy today and routed the body. The smallest bearing that came in the larger rabbit bit set was a perfect match for the flush edge router bit. No adjustment necessary except for the vertical depth adjustment.
Here are all the pieces gathered. BTW: The Mitutoyo dial calipers are 34 years old and are like new....
Here is the width of the binding. It is a little rough on the edges and I'll make adjustment for the depth of cut to sand the sides flat.
Thin stuff....a little skinnier than specified.
Spunky99 is offline   Reply With Quote
