Originally Posted by Gee
Also from memory the GA-5 has no 1M resistor from the input to ground. That was an error in the early Gibson schematics that got carried forward.
Not an error. When you plug your guitar in, it's resistance to ground takes the place of that grounding resistor. Gibson factored that in. As long as you are using a guitar, you're fine. If you plug in a mic for harmonica, it can cause big trouble with runaway gain.
So for harp players, a 4.7 meg resistor should be installed from the input to ground in vintage GA5s and in these new ones. For guitar, the input should be left as is.
