Old March 9th, 2008, 07:28 AM   #364 (permalink)
Gee
Gee's Avatar
If someone could monitor the voltage when the power is turned off then you may find that the caps drain naturally. Otherwise you could put a resistor of about 220K (1W) across the first power cap and then the amp will drain within 20 secs or so after the amp is turned off.
It is always good life prolonging practice to check the caps voltage every time you work on it anyway.
Gee is offline   Reply With Quote
