you can't do that ,the F tuners require larger holes so the Kluson style tuners will "float" in the existing holes,you will need conversion bushings for a snug fit.
Furthermore you will have to drill new mounting holes cause the screw pattern is different.
Is this also the case for the factory tuners on a MIM standard?
Thanks,
Rick
