Originally Posted by Rob DiStefano
I'm gonna add a 1/4" 8 ohm speaker jack to run an external cab (since the Heyboer OT is 4/8 ohm tapped). The JenNeo 2x12 I'm building will be a nice tonal experiment.
If I Am reading this right, you can use the 8ohm lead for an external cabinet while using the onboard 4 ohm at the same time?
Or is it a one or the other kind of thing?
