Originally Posted by imwjl
Guitars that have or had a pickup are wider and that's not a Martin issue per se. All Larrivees have a wider end pin regardless of electronics.
Bob Colosi sells a bone end pin with standard size with larger end to accommodate guitars with the larger hole. He also sells a bone strap pin for your neck heel if you want that.
I have a $99 Rogue that has a pickup/electronics but the end pin is normal, which also has a hole that I can plug a cable into.
That's what I'm talking about. Is there anything I can do to get something like that on my Martin?
I'm not gonna get the Bob Colosi bone end pins because
1) they're expensive
2) I would have to drill in a new hole on my guitar for that endpin. I want something to put on where the pickup leads out of the hole.
