Old February 18th, 2008, 10:33 PM   #5 (permalink)
eryque
eryque's Avatar
It definitely sounds like you're describing the endpin jack, which is always wider than a standard strap button regardless of the guitar's maker.
You can try using a strap made of softer leather that will stretch more, you could also find a tapered rod of some sort you could use to stretch you strap hole on. You could also try punching a bigger hold into the strap, being careful to locate it in a place where it won't likely pull out right away.
my blog: eryque.blogspot.com Updated 10.27.07
