Old February 18th, 2008, 09:50 PM   #4 (permalink)
imwjl
Guitars that have or had a pickup are wider and that's not a Martin issue per se. All Larrivees have a wider end pin regardless of electronics.
Bob Colosi sells a bone end pin with standard size with larger end to accommodate guitars with the larger hole. He also sells a bone strap pin for your neck heel if you want that.
imwjl is offline   Reply With Quote
