Old January 19th, 2008, 03:19 AM   #25 (permalink)
Steve G
Steve G's Avatar
I don't think you can safely remove the fret; you're gonna disturb some wood, it will look funky.
I keep painting and modding on 'em, using them as test beds, and when one guitar is as far as it can go, I give 'em to my kin or to folks that have helped me get along in this lil mess we have going down here. Anything you can learn about modding on a $ 69 Squier 51 that will help prevent a $ 800 guitar mod from being buggered is good economy to me.
Bubbanov
Makes sense to me Mr. B, they're great fun to mod and play with. I've tried pulling a fret a fret before and it certainly wound up looking 'funky', however -
Originally Posted by Rob DiStefano View Post
I remove the 22nd fret with fret pulling pliers, fill the fret slot with a CYA glued slat of wood stained as near to the fingerboard color as possible, run the neck heel back on stationary sanding wheel to remove most of the hang-over, then finish up with hand sanding and some clear coats.
..maybe I'll give it a go with your method Rob. I was probably a little aggressive with the sander last time
I just dont like the look of a 22 fret neck more than anyhting.
Thanks for your help guys, look forward to seeing your guit modded Rob.
"He was a drinkin' man with a guitar problem..."
http://www.myspace.com/stevegiddings
http://www.myspace.com/hiandlonesome
Steve G is offline   Reply With Quote
