I used it yesterday at a full band rehearsal and I'm even more excited by it. It's inspring to play through and I think that's the highest compliment I can pay any peice of gear. I can get the most controllable feeback at such low levels that I have to laugh. I'm still exploring the controls and finding new sounds. You can turn off the negative feedback loop and obtain an amazing "amp on the edge of meltdown" tone. To really exploit the amp's capabilities you need to use an A-B switch. My current favorite use for this is to set the gain on the "Marshall" channel and the master volume setting to the point where I can use the guitar's volume knob to push the amp into output stage overdrive. I then step on the AB pedal (I have a Morely Tripler) and add the "Fender" inputl, set to have a little more gain. This effectively fattens up the sound and adds a little midrange boost on top of sending the amp into a wonderful touch sensitive level of overdrive-sustain that reminds me of a 50 watt Marshall half stack. But, at a volume level that doesn't make everyone else glare at me. Wonderful!
Reason: spelling
