Old January 2nd, 2008, 11:45 AM   #9 (permalink)
JohnnyCrash
You drill a hole in the chassis large enough for the driving bolt to fit in.
Then you put the bolt through the hole with the die threaded on at one side. You then thread the cut/punch/bit on the other side and tighten it all together. The die and cutter eventually meet in the middle where the chassis used to be :)
