Here's the assembly after the interior is cleaned up..
I let the glue set for about 10 minutes or so, then remove one clamp at at time, to clean the glue from the outside. I'll pull a clamp, wipe the glue, replace the clamp, and move to the next one.. Just keep working around the piece until it's done. Then leave it overnight.
I'm a little obsessive about this stuff, as I will still be sanding the whole edge to get to my finish shape, but it is easier to sand clean wood than to clog up sandpaper with glue, and sometimes the glue will soak in too deep if left on- which can discolor the finish. Better to wash it off as I go.
Another thing to notice is the placement of the cam clamps, they are at the neck pocket area, the tail area, and the bridge post area. One more in the center of the beam, for good measure. This will ensure stability and no voids.
