Originally Posted by stxrus
a nice closed back 8ohm cab will add a lot of "body"
Be aware that this could harm the amp. The C30 is designed with a 16 Ohm speaker and the extension speaker should also be 16 Ohms. The speaker and the jack are wired in parallel. When you plug into the extension speaker jack it switches the transformer to the 8 Ohm tap. Two 16 Ohm speakers in parallel is 8 Ohms total.
