What amp are you using? Does it have onboard reverb?
I would suggest, that if it does, go get a good compressor, and a distortion or overdrive unit and grow from there. You should be able to cover most of the material with this set-up. As time goes on you might want to add a delay. But right now focus on the comp and drive.
éí 'aaníígÓÓ 'áhoot'é
Would you mind holding this bag while we go through the custom shop?????
Redd Volkaert is a Jedi Knight at one with the Force!!!
