Old November 27th, 2007, 02:52 PM   #610 (permalink)
jwells393
jwells393's Avatar
More perplexing to me right now is the pickguard.
You've probably already thought of this but it seems like you could lay a pickguard on the upper part ........... then lay a pickguard on the lower part.......... tape the pickguards together and use that to draw and cut your rough template. Then if you have a normal Tele pickguard template use it to cut neckpockets, bridge notches, control notch(es) and the lower horn in the rough template. Finish any other parts with sandpaper and files. Then with the beast assembled test the template for fit before attacking a big piece of pickguard material.
