I posted this on the Ceriatoneforum but I know there were a few interested in the amp here. There is nothing technical just some comments. This is all IMHO of course.
I have had the Overtone for more than a week now and have been playing it and A/B'ing with the D'Lite. I only had one chance to get it up to gig volumes at a jam the other night so most of my observations are of the amp at less than perfect (lower volume) conditions.
That said,, Let me first dispell the sentiment that there might be something wrong with the amp. (
People were grumbling waiting for a review)
Trust me there is NOTHING wrong with the Overtone. If a negative thing could be said about the amp is it has far too many great and useable tones and it's going to take much longer than a week to get aquainted with this "multitalented" amplifier.
Let's begin with the cleans....
Like the D'lite you have two distinct flavors of clean at your disposal. With the clean volume down and the master up there is a lot of beautiful sparkle and jingle like any good blackface and the bright switch in conjunction with the tone stack can get you all kinds of variability on that theme. If you crank up the clean channel volume (about 2'oclock) and keep the master low the cleans warm up (like all similar amps) but the range of clean from dark to sparkle can be finely adjusted with the tone tack, bright switch and the deep switch, which itself adds a very attractive scooped tone where the amp is warm yet sparkly on the top end. Engage the PAB and your mids come alive for a lot of cut in a big band setting. I don't know why but the treble pot in the tone stack remains somewhat interactive with the PAB engaged. It made me think of the 5E3 tone/volume interaction and actually makes for a nice jazz tone....lol. Between all of the switching options and interactivity there are seemingly limitless permutations on the tones you get in the clean channel alone.
If I were to make a generalization on comparing the cleans of the Overtone to the D'Lite it would be that the Overtone is bigger and bolder. The mid focus is very present but there is also the ability to dial in more highs and significantly more lows if desired.
The OD channel.....
The jury is still out on this one. Not because of anything bad but for the most part I haven't had all that much time to dig into it. In it's stock form the amp is tailored for humbuckers ( like all of these D flavoured circuits) and the wide range of the aforementioned functional clean tones goes for the OD channel as well. On similar settings as the D'Lite the Overtone sounds very um ....similar...I mean VERY close. However, I think it's just my style of playing but I just can't seem to get that "chewy" ScottL tone thing happening (on either amp). The Overtone has quite a bit more punch than the DL so it can do the Marshall grind very nicely. Again, I have to get into the amp more before I can really say any more.
The FET input??.......haven't even tried it yet....so no comment.
Build quality......
I've put together quite a few amps and I know I couldn't do any better than this. I don't think there are any components that I would substitute on the basis of poor quality. Maybe a few Kiwame resistors....lol (I'm on a Kiwame kick these days). I don't know if it's just me but there seem to be a few too many Vishay Dales in here.? I always like to see a dash of CC's for flavour....well, maybe not in this amp.
The chassis is well made and is plenty strong enough to support the rather hefty transformers. I like the fact there are eight bolts to help distribute the hanging weight on your cab. One should consider bracing if you are going to be rough on the cab.
Last but not least......
If you can, try as many different tubes as a possible. These amps get the majority of their tone from the preamp. I've settled on Mullards and Syls for pre's and Winged C's for the power section.
Speakers, too. I am using an Eminence RW&B but as soon as I find one I'm going to try a G12-65 as that is the standard by which all D style amps are played through these days.
All in all, the amp is a tweakers seventh heaven but as stock it can hold it's own to any of the goliaths out there.
And finally...lol At the recent jam there were several BF Fender's, a signature Two Rock, a Maz 18, a brown Vibroverb RI and my D'Lite and the Overtone (just the chassis). The Two Rock and the Overtone were the stars of the party and not to elaborate but .....I don't see any need to be buying a $10,000 Two Rock anytime soon...
Cheers,
Chris
